Sheet metal help, am I being a bit thick?
owen_sparks
Member, Developers Posts: 2,660 PRO
Hi folks.
Not sure if I'm being a bit thick or if this is a bug. (SM newbie I'm afraid.)
In the model below I'm close to what I'm after but the side flanges bend the wrong way, all 3 should have the same orientation. However If I flip their direction the model fails. I'm confused as I don't see how reversing the direction of the bend would change the geometry of the flat part? How can one direction be good but the other bad?
If anyone is willing to give up their time to educate me I'd be grateful.
The issue is with the last feature named "Flange Sides"
https://cad.onshape.com/documents/db6a3f102bd3cfda286f33b5/w/8e791331de379898b7de569b/e/2fd6c13bb334e0d332bc756c
As an aside these things cost £55 each in the UK. If I can cut them in house onshape will have paid for itself providing we need at least 2 a month
Cheers,
Cheers,
1
NeilCooke
Moderator, Onshape Employees Posts: 5,930
Hi Owen, as a workaround, rather than use move face you can manually cut 2 bend reliefs before the first flange then use the shortened face to create the first flange.Senior Director, Technical Services, EMEA5
If you do your own corner relief, you can get the shape you want. See here. https://cad.onshape.com/documents/58a484bdbaa7e90f794b330b/w/cc7424e2fb320131e13b0327/e/a3c7094d0beea8b3a325d107
Cheers,
Thanks helpful help dept.
OwS.
