Sheet metal help, am I being a bit thick?
edited February 2017 in Community Support
Hi folks.
Not sure if I'm being a bit thick or if this is a bug.  (SM newbie I'm afraid.)
In the model below I'm close to what I'm after but the side flanges bend the wrong way, all 3 should have the same orientation.  However If I flip their direction the model fails.  I'm confused as I don't see how reversing the direction of the bend would change the geometry of the flat part?  How can one direction be good but the other bad?
If anyone is willing to give up their time to educate me I'd be grateful.
The issue is with the last feature named "Flange Sides"
https://cad.onshape.com/documents/db6a3f102bd3cfda286f33b5/w/8e791331de379898b7de569b/e/2fd6c13bb334e0d332bc756c
As an aside these things cost £55 each in the UK.  If I can cut them in house onshape will have paid for itself providing we need at least 2 a month :p
Cheers,
  • lanalana Onshape Employees Posts: 761 image
    This is a bug on our side. Will try to fix it for the next release.
    If you do your own corner relief, you can get the shape you want. See here. https://cad.onshape.com/documents/58a484bdbaa7e90f794b330b/w/cc7424e2fb320131e13b0327/e/a3c7094d0beea8b3a325d107
    Thanks @lana appreciated.
    NeilCooke said:
    Hi Owen, as a workaround, rather than use move face you can manually cut 2 bend reliefs before the first flange then use the shortened face to create the first flange.
    Thanks @NeilCooke that worked perfectly and is actually a nicer workflow to boot. Result :)
    Cheers,
    Woo-hoo.  Notification from the OS help department saying it was fixed, an update of the doc to latest version of Ons, supress the failing feature and rebuild and all is perfect.
    Thanks helpful help dept. :)
    OwS.
