Looking for modeling technique suggestion: Sweeping a variable profile using 2 different sweep paths
StephenG
Member Posts: 384 ✭✭✭
I am trying to model a replacement cover to a set of microwave cookware. (Replacement cover is no longer available. I plan to print a replacement on my new 3D printer.)
Is it possible to sweep a profile whose ends are connected to different paths?
Note: One curve in the profile is partially constrained to allow the profile to reshape itself as it is swept along the 2 profiles.
I have done this type of surfacing in other CAD systems, just want to know if Onshape (in its present state) can do it. I cannot figure out how to effect it.
If it cannot be done I am guessing I will have to revert to manually constructing a series profiles and lofting the surface.
NeilCooke
Moderator, Onshape Employees Posts: 5,988
@stephen_gertsch sweep only works with one profile. I would remove the R1.25 and make two sweeps, then add the rad back after. You could also build the final shape using 3 extrudes and 2 fillets.
Senior Director, Technical Services, EMEA5
I really like your suggestion.
Note: I created a "Branch" for the 1st time. I created a branch to isolate using a different modeling approach to create the surface. Up until now I have simply "Duplicated" the Part-Studio to try an different modeling approach. I am beginning to appreciate the power of branching.
(Actually, I did 2 sweeps: 1 sweep for the outer and 1 sweep for the inner surfaces, then a loft to connect the 2 surfaces.)
Tried using the edge of the existing surfaces as "Guide Lines" but the "loft" would fail. Going to read up on use of guide lines.
Get rid of the bottom half of your paths so you just have the top 180deg then place a copy of your sketch at 9,12,&3 O'clock. Choose those as your loft surfaces and your inner/outer sweep paths as the rails.
First problem: I selected edges of the surfaces as guides. Guide curves have to be their own sketches (Why?)
Second problem: I created the projected edge lines as construction line type; they need to be "solid". (Why?)
Now you tell me I cannot join/merge the surface patches into a single surface. Oh joy.
I will share the Document with you so you can show me how you would do it...
From what I can determine you (OnshapeSupport) should already have access to it.
I tried explicitly sharing the Doc with you "NeilCooke" but it wasn't recognized.
Regards,
It is very important to know when to use surface modeling. Even if you have "organic" shape all features that look "prismatic" should be done with solid modeling, after you finished with surfacing.
projektowanieproduktow.wordpress.com
LearnOnshape facebook group
Thanks Ben, I appreciate the i@Ben_
Cheers, Owen S.
My real problem is that my 3D printer is too small to print the full size part. I isolated the critical interface feature(s) and "pie" cut the model in 3rds and glued them together to complete the fit check. I am glad I did because I had to tweak a couple of dimensions to get it to fit exactly as the original with its "wiggle room" clearance. I used a "branch" to isolate the main model work from what had to be done to it (pie cutting) so I cut complete the fit check. Branching worked well for this purpose.
I checked around at local 3D printing services and I got a quote of $290 to print the full up model. I am committed to getting this thing made, but I am not $290 committed. I will resigned the model to be an assembly of parts that I will glue together. I will add additional features (channels matting edges) to facilitate the assembly.
I just finished up the base model by adding the vent/drain feature.
The vent/drain feature was little trickier to build than I thought it would be. I spent some time finding the right number and application order of fillet operations to get the thing done.
All in all, this has been a fun exercise in learning to use Onshape and my new 3D printer.
