Select edge of extrude? (resolved)
laird_broadfieldlaird_broadfield Member Posts: 42 ✭✭
edited July 2015 in Community Support
I'm suddenly having trouble doing something I swear I've done before: selecting edges (not the face) of an extrude.
Make a rectangle, extrude.
Now, I want to select the edges of the top, and chamfer the edges.  I can't convince the UI to select individual edges, only the face.
This matters, because what I really want to do is select just three of the four edges for chamfering.
(Similarly, put a hole in it.  I want to chamfer just the outer edges, not the hole.  Without reordering the operations, I can't seem to do that anymore.)
  • abefeldmanabefeldman Member Posts: 166 ✭✭✭
    @laird_broadfield - You should absolutely be able to select the edges of an extrude.  What browser are you using? The first thing I'd recommend doing is a hard refresh of the page by holding Shift and clicking the reload button.  If that doesn't help, can you open a ticket by using the ? -> Feedback option and share the document with Onshape support?
    Abe Feldman
    UX/PD/Community Support
  • brian_raffertybrian_rafferty Member Posts: 2
    I also am not able to select teh edge of an extrude now...is there a setting I am missing or something?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,944 image
    @brian_rafferty what are you trying to do? If you are trying to select an edge to fillet and it won't then please open a ticket or check your browser version. If you are in a sketch and trying to reference an edge, Onshape will only select the edges of the face you used as a sketch plane - you must add constraints manually to other edges in the model.
