FeatureScript Beams - Referencing to Profiles in another document
wolfgang_maierwolfgang_maier Member Posts: 39 ✭✭✭
Hello,
i copied featurescript beams to my document (Tor+Rahmen Stahl). I created Beam Profiles in another document (document Beams+Profiles).
When i import Beam Profiles in featurescript beams the tool asks me from where to import. I say: Other documents - Beams+Profiles.
As result i can only import V5 of my beam profiles and not the main version. Both of the scripts are commited.
What is my error?
regards
Wolfgang
  • ilya_baranilya_baran Onshape Employees, Developers, HDM Posts: 1,255 image
    Without 100% understanding your setup, the first thing that comes to mind is that "main" is not a version.  Committing the FS isn't enough -- to import from another document, you have to make a version (like V6) of the beam profiles document.  Open that document and click the create version button next to the version graph button in the top toolbar.
    References in Onshape take two forms:
    • Links within a document can be to a workspace, and will automatically update every time the referenced data changes.
    • Links between documents must be to a version. This design is to avoid unintended breaking of other documents when you change something referenced elsewhere. When you create a new version of the linked document, in FeatureScript you'll need to replace that import line with a new import of the new version.
    It sounds like the best solution for you is to create a version of your latest beam profiles, and import that version in the Feature Studio.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,983 image
    You should also not be splitting up the profiles and the feature - keep both together in one document, create a version, then add the feature to your toolbar so you can use it anywhere.
