Driven dimensions in sketches
Hello-
The ability to display Driven dimensions in Sketches would be helpful
Or maybe I can't find them?
Thanks, Devon Sowell
Devon Sowell
Engineering Consulting Partner
Professor, Engineering Technology, Palomar College, San Marcos, CA
sowelldevon@gmail.com
760 809 9046
CarlsbadCAD Carlsbad,CA
760 809 9046
Are driven dimensions a hint at equations too?
I ask, because that's what I use them most for...
Dries
Can you elaborate on this thought? What would you use them for? Do you want driven dimensions for parts in part studios, assemblies, or both? The more information about what you want/need, the more informed we can work on creating a viable, useful solution.
I imagine equations take a lot of thought in how you want to present them.
Dries
1) Display a measurement on a sketch to help during interactive iteration of the design.
1a) Sometimes I'm uncertain what dimension should be driving and what should be driven. This involve toggling driving/driven the two (or more) dimensions I'm considering.
2) Display a breadcrumb for the next engineer as to what is important in this sketch (combined with turning off visibility (hiding) of non-important or 'constant' dimensions in the same sketch).
3) Create an input to an equation
4) Create an input to a complex parametric annotation, usually in a drawing. The driven dimension gets hidden and the target annotation gets the value embedded into it. (This is an extension of 2).
Attaching driven dimensions to the geometry (in essence, creating a geometry measurement you can reference) in addition to sketch elements, is relevant in all these cases. The usefulness of a measurement on the geometry as input to equations is obvious I hope.
The usefulness of a geometry measurement as input to annotations on the model is clear if you remember that half the purpose of a solid model is to capture and communicate the design to other engineers and communication is all about extracting the salient information and presenting it in a form your audience can understand.
What I understand by "Dimension Driven" is very diferent to what in parametric is.
Part Studios for now. I can't think of situation where Driven dimensions are needed in Assemblies. When Onshape Drawings are created, we'll need Driven dimensions in those also please.
760 809 9046
