opExtrude with UP_TO_NEXT
emagdalenaC2iemagdalenaC2i Member, Developers, Channel partner Posts: 867 ✭✭✭✭✭
edited February 2017 in FeatureScript
Hi
I am trying to simplify a FeatureScript using the UP_TO_NEXT option in opExtrude instead of BLIND, but it doesn't seem to work.
This is the part of code:
            // Extruye el panel hasta la cara opuesta
            opExtrude(context, id + "extrude1", {
                    "entities" : frameRegionToExtrude,
                    "direction" : framezDirection,
                    "endBound" : BoundingType.UP_TO_NEXT,
And this is the FeatureScript notices:
@opExtrude: EXTRUDE_UPTO_NEXT_NO_DIVISION
166:12
onshape/std/geomOperations.fs (opExtrude)
567:13
AluminiumProfile (const AluminiumProfile)
52:17
onshape/std/feature.fs (defineFeature)
605:21
Estructura (const buildPrivate)
608:13
27:17
onshape/std/partStudio.fs (definePartStudio)
17:12
Estructura (build)
7:12
Estructura (main)
I am missing a parameter or anything else?
Un saludo,
  • ilya_baranilya_baran Onshape Employees, Developers, HDM Posts: 1,263 image
    The error suggests that the code is fine, but the extrusion is failing in the part studio because the "next" body doesn't completely bound the extrusion (its projection doesn't cover the profile).  I think for anything more specific as to why it's failing, we'd need to see the part studio and the code.  Hope this helps.
  • emagdalenaC2iemagdalenaC2i Member, Developers, Channel partner Posts: 867 ✭✭✭✭✭
    ok, thanks
    It doesn't "completely" bound the extrusion
    Un saludo,
