How would I create the female threaded hole from a screw I already made?
brian_dady
Member Posts: 5 ✭
I have already made a screw and I am wondering if there is a way to stick it in a solid part and do a Boolean subtract kind of a thing. Essentially, if one starts with a screw, how do you make the female threaded hole for it?
Thanks!
Brian
Thanks!
Brian
NeilCooke
Moderator, Onshape Employees Posts: 5,929
Hi @brian_dady you can do exactly that (and use Boolean subtract tool
) - also in there is an offset option that you should use otherwise the screw would be too tight. In reality a female thread has its own profile that should be modelled separately. Senior Director, Technical Services, EMEA5
Thanks!
Brian
