Loft Cut guides question
I'm trying to transition one lofted cut profile to another along a curve and am having issues. I've attached two pictures, in the first you can see the profiles I'm using. The loft works but I end up with a straight cut line. In the second picture you can see the arc I would like to use as a guide (orange). Onshape will not generate the loft when I select the guide. Any ideas? Assume there is something wrong with the profiles. Thanks in advance.
Let me know if you need more help!
Jason
I found this discussion via search
https://forum.onshape.com/discussion/388/how-to-control-a-sweep-end-profile
Not sure replace face would help as I need it to gradually taper to the second sketch profile.
Try adding another guide to your loft to keep it in line. Make sure to use the pierce constraint when making the guides!
Best,
Jason
Pierce isn't necessary for all projects, but its a great way to really pin down your lofts by making sure the sketch profile actually intersects the guide, as opposed to projecting the sketch to the guide.
Pierce in help
Loft in help
Good luck George!
