The same extrude/remove operation I've used repeatedly is now failing on one specific part
ronald_ulyssesronald_ulysses Member Posts: 1
edited March 2017 in Community Support
https://cad.onshape.com/documents/b4896ac8062feae294b301ab/w/3cfcea45f0331a6f213af5f5/e/5248c611ccda77ac8f5df691
See: Extrude 4 & 6, which are identical to 3 & 5 which worked perfectly.
I've got three other parts using the same original cad file that also worked fine, so there's no logic I can discern.
    edited March 2017
    Hi @ronald_ulysses edit extrude 4 & 6 and change from New to Remove
    Sorry I see your issue now, hang on.
    For some reason Parasolid does not like it which seems strange. If you can add Fillet 2 after the holes that works. If that is not possible please open a support ticket.
    Wait - the arcs in your DXF profile are not tangent which is quite likely the cause
