How to delete faces from an import (solidworks or iges)?
reuben_kraft
Member Posts: 10 EDU
Hello,
I was able to successfully import a part from SolidWorks and want to edit the part. Some things I can do like extrude, split curves, etc. However, if I try to delete a face, the "Delete face" item under features is red and when I hover over it, it says " Delete face 1 did not regenerate properly: Select faces to delete"
I was wondering how I can do this. The reason I want to delete faces is to simplify or de-feature the part (I plan to send to simscale for simulation). My plan was to delete and add a simplified geometry component that is more easily "meshable".
Thank you.
Thank you.
OptionsJake_Rosenfeld Moderator, Onshape Employees, Developers Posts: 1,646Hi Reuben,
Can you share your document here or post some screenshots for context? My best guess is that you are just selecting the bottommost face of a pocket or the topmost face of a protrusion. To defeature you will need to select all the faces of a pocket or protrusion. See the direct editing video here:
https://cad.onshape.com/help/Content/deleteface.htm
Let us know if this was your issue or if there is an additional problem.
EDIT: The specific text of your error message seems like there aren't any faces selected. Is anything showing up in the box above the 'Delete fillet faces' checkbox? It should say something like 'Face of <something>'.
Reminder: if you are using the 'Create selection' dialog you will need to click 'Add Selection' before that selection actually makes its way to the 'Faces to delete' box of the feature dialog (I think this is probably the problem you are experiencing)Jake Rosenfeld - Modeling Team5 -
OptionsNeilCooke Moderator, Onshape Employees Posts: 5,426Senior Director, Technical Services, EMEAI5
https://cad.onshape.com/documents/a4dae015a67dfc4426a9e0df/w/dcd99f9ba4b00eb472e5c793/e/f4cd6897690bdf6455b486d6
I was trying to delete any of the outside faces. I think you may be right that this is the topmost face of a protrusion, but I am not sure where the base sketch started.
See my edit. Are you sure there are actually any faces selected for the deletion?
I'd like to try a couple things, is there any chance you can make the document public so I can copy it and play around? If you'd rather not you can file a support ticket by clicking '? -> feedback' in the upper right corner of the document.
https://drive.google.com/open?id=0B2jKCiWMO3weZEQxNmRrUzlOYWs
I defilleted everything just so you could see how it's done. Let me know if this isn't what you meant to do:
https://cad.onshape.com/documents/58c051f8e493aa0f85abe0cc/w/fbe091f472b0f64e5348c638/e/cbd31a606b5bda61d936d303
If you want to be able to see the inputs to the features by rolling back/double clicking on them, you can copy the document back from me.
You could use the move/create face command and convert all other faces except this to surfaces to but not sure that's what you are really after.
I think what you want is just to extrude the face in with a remove, is this the result your looking for.
https://cad.onshape.com/documents/58c0538015bae2107af929d9/w/530b09d343b9976a228105a6/e/72830c3d67b81962fba02e53
I don't think delete face is the right workflow for this because it is not a solid protrusion. I've done what you want with 2 'Move face' features:
Yes, thanks so much. I think I understand what you both are saying with the 2 move successive commands. I played around with it a bit and see how that would work, although I am not sure how you sealed up the hole. This problem is a practice for what I am really trying to do and that is to remove a similar structure but is threaded. I have a circular piece of a part that looks just like this but has threads. I want to remove the threads so I simplify and can make a finite element mesh.
So next question, is how would you remove complex faces like are on threads? Sorry for all the emails, but I think this sort of thing would be useful for the general community.
https://cad.onshape.com/documents/54911a92f479626781c654b3/w/af59c558d5fb80b48b2383a6/e/f3126373a0965d466532fb08
