Help with Boolean Subtract on Imported Part
ryan_quinnryan_quinn Member Posts: 1
edited March 2017 in Community Support
I am trying to make an enclosure on a OBD2 Connector. So I found a free model online and imported it into onshape. When I try to use a Boolean Subtract on the imported part and an extrusion on the section I need, it always gives an error. If not an error it just gets rid of the extrusion. Any help would be useful! I can post pictures if they are needed. Thanks in advance.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,987 image
    Please post the URL to your document and some pics of what you are trying to do and someone will help you.
  • dara_o_heidhindara_o_heidhin Member Posts: 3
    edited November 2017
