Copy with transform command
Is there a copy ability when using the transform command in sketch? If not it would be nice to have the ability when moving or rotating a sketch entity to have the ability to keep the selected entity in its current location and make a copy of it to move or rotate.
NeilCooke Moderator, Onshape Employees Posts: 5,868
Copy and paste - any constraints between the copied entities will be maintained. You can then transform them to where they need to be.Senior Director, Technical Services, EMEA7
