Making a corkscrew
bao_nguyenbao_nguyen Member Posts: 3
edited March 2017 in Community Support
Hi!
I just started using Onshape and I love it. But I have trouble making the end part of the corkscrew, the spiral. Would appreciate any help.
  • mahirmahir Member, Developers Posts: 1,315 ✭✭✭✭✭
    To make the sharp tip you can either loft to a point or just extrude the flat face with draft.
    I'm in hurry, so I just tip you with the tools create helix wire and sweep along that. Cut the end to desired shape if needed.
    Create in parts and use boolean to combine.
  • bao_nguyenbao_nguyen Member Posts: 3
    Oh man! thank you. I will try
