Revision Individual Parts, not document as a whole.
edited March 2017 in Product Feedback
I'm sure this request may be a duplicate, but a search didn't find anything similar so....
I'd really like revision control to be extended to individual parts not just to documents as a whole.
Current workflow
Assume a linked docs of library parts for example
Add new part to library
Now every doc linking to the library reports that it needs to be updated.
With individaul part revisions this would be gone.
Cheers, OwS
    edited March 2017
    basically it is about having access from the assembly tab to the multiple auto-updating workspaces of the part studio within the same project, or the other one. this requares to implement special type of workspace and user could select to create a global project branch, or branch which parts will be accessible to all workspaces of assembly tab. this mechanism of special branching would behave like part configurations. of course using auto-updating parts is across ideology of OS, and user can "shoot yourself in the foot".
    that what i think of this problem.
  • lougallolougallo Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,015 image
    @owen_sparks  I moved this from the improvement voting since this is a very wide request.  We are working on the notion of a part and all the process that is surrounded by it with variants, revisions and thoughts on how do you release a part from Onshape.  There will be many efforts to address this question.
    Hi @lougallo
    Will you OS chaps please make up your mind...
    Can you guys make an improvement request (on the right side of this page) rather than +1ing on this post? That way your votes will automatically be in our system.
    ;):p
    @owen_sparks
    @lougallo definitely outranks me about what belongs as an improvement request and what doesn't ;)
