How do I edit a basic sketch?
tony_uptontony_upton Member Posts: 1
I have followed the instructions and can produce a (for example) rectangle in a particular plane. I can extrude the rectangle in all planes, but the system will not allow any other editing/modifying; eg, holes, fillets or extensions. What am I doing wrong?
  • brian_jordanbrian_jordan Member, Developers Posts: 144 ✭✭✭
    In the feature list on the left of the screen you will see your sketch listed, probably as "Sketch 1". Right clicking on this will open a menu the second item of which is "Edit...". Selecting this will open the sketch for further editing.
    You can also double click any feature in the feature list to edit it (as a shortcut instead of right click > "Edit...")
    @Jake_Rosenfeld Thanks - that one had passed me by.
