Is there no way to import a STP into an active studio?
don_whitmire968don_whitmire968 OS Professional Posts: 21 PRO
I've researched through the threads with some detail and have not stumbled across a solution.
    edited March 2017
    You can't directly import anything into existing studio. But you can get imported parts easily in, depending on part count of your step file.
    - You can import into separate studio and derive parts to existing studio (check help for positioning)
    - Import first and continue modeling into same studio
    If you think importing to existing part studio should be possible, use feedback to share your need with Onshape - there might be others and someday such functionality might be available.
