How to make arc go up
Hello,
I would like to ask for help. I need to make a path for swipe that goes up & down based on some profile. I have managed the straight parts. Unfortunately don't know how to manage arcs. Do You have any idea?
Here is what I have done so far (the final solution will be much more complicated, this is just a prototype to test how to)
https://cad.onshape.com/documents/c8a8297d2d44f17f010171e6/w/bd77e1abab5be6f42f223f44/e/1150e4f46d67677286934073
By arcs do you mean this?
If so then pretty much the same concept as your flat profile.
There are no 3D sketches yet, so you have to take it in steps
If you don’t care about full control of the overall shape, you can use a 3D spline with guide points and continuity constraints.
I believe you can get there with a few less steps by using the recent addition to our toolset of "Projected Curve".
Steps 1 and 2 as per @florian 's method but with the curve doing the grunt work of steps 3-5.
https://cad.onshape.com/documents/4a14c236a38c5368c8ec9a74/w/d4dbd2385ddf49c915b29327/e/b9ed7334318b0203accc337c
@john_mcclary is this how you went about it? (I think your doc might not be public.)
Happy CADing, Owen S.
And It looks like I may have deleted that docmument. oops
