Building a model using variable
![mladen_sudar](https://cad.onshape.com/images/placeholder-user.png)
Can model be created with variables A,B,C,D... and that variables to be controlled with like excel spreadsheet or similar? And then going through rows model will adjust? Is this possible and if Yes can You explain how?
Look at Onshape help for variables, there's also really cool way to create 'option variable' that let's you quickly select different set of variables.
Use feedback to add ticket for spreadsheet driven vars, that is definitely needed (though I would prefer google sheets over excel)
