Featurescript - query/delete all sketches
leon_pootleon_poot Member, Developers Posts: 87 ✭✭✭
I want to clean up my Part Studio, so that when I derive it in another (using opMergeContexts in FeatureScript) I don't get all the sketches and points and all, but I do want to import all parts and surfaces at once.
Either I can query these one by one, calling opDeleteBodies on all the queries, but I'd really like a smoother version where I don't select these by hand, but automatically query them.
Can anybody point me in the right direction for querying all sketches at once?
  • ilya_baranilya_baran Onshape Employees, Developers, HDM Posts: 1,255 image
    In the next release, we expect to have a convenient query filter for sketches.  Currently, I'm not aware of a way to avoid querying for the sketches one by one by id.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,979 image
    Would qBodyType work using WIRE?
  • leon_pootleon_poot Member, Developers Posts: 87 ✭✭✭
    Filtering a query (all WIRE and SHEET bodies, and VERTEX entities) using evOwnerSketchPlane() works excellent. Thanks.
    var qAllSketchEntities = qUnion(filter(evaluateQuery(context, qUnion([qBodyType(qEverything(), BodyType.WIRE), qBodyType(qEverything(), BodyType.SHEET), qEverything(EntityType.VERTEX)])), function(entity)
            if (try silent(evOwnerSketchPlane(context, { "entity" : entity })) != undefined)
                return true;
            else
                return false;
    edited April 2017
    I simplified your code to this:
    var qAllSketchEntities = qUnion(filter(evaluateQuery(context, qEverything()), function(entity)
            return (try silent(evOwnerSketchPlane(context, { "entity" : entity })) != undefined);
    It gives a different number of bodies in the result, don't know why, but it works.
    Edit: although using the profiler I see yours is faster due to not testing solid bodies.
    @NeilCooke, looks like your code goes through all entities, not just bodies.
    Setting it to qEverything(EntityType.BODY) picks up all sketch bodies and makes the code 3x faster too!
    Thanks @NeilCooke That makes perfect sense.
    I tend to think of only solids when I see "BODY", so I took some unnecessary detours in my code without thinking.
