overdefined engine assembly
Laughlin_MccooeyLaughlin_Mccooey Member Posts: 3 EDU
in assembly 3 I have somehow overdefined the assembly. this happened after adding the mates slider 1 and slider 2, these mates keep the piston inside the cylinder, after messing around with the mates I discovered that if I remove revolute 7 and slider 2 the assembly seems to work fine, other than one of the pistons going into the engine block and the crankshaft being inside the physical engine block, it isn't crucial as i can test that at least one piston works and as long as the crank shaft is where it should be it will rotate fine, but since this model is just theorhetical i'd like to be able to twist the crank and have everything move.
Document link: https://cad.onshape.com/documents/2bb4380cebbc5a3e6aa5612d/w/47c1e8cc9fdbb16f822eff8c/e/0d42f3543dea18647006c301
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,848
    Try using a cylindrical mate instead of a revolute. The slider mate is holding the axial position so there may be a tolerance issue.
  • Laughlin_MccooeyLaughlin_Mccooey Member Posts: 3 EDU
    I tried using a cylindrical mate for where the crank connects to the engine blovk, which is what i assume you were talking about, however after replacing the slider mate (and then trying with a cylindricle mate) the piston still exits the engine block.
  • Ben_MisegadesBen_Misegades Member Posts: 133 ✭✭✭
    Can you share the document?
    edited April 2017
    I added a document link in my original post, you should be able to make a copy; however I did edit many of the parts to allow them to be able to be physically assembled
    Correct, the link is there, but it states that it is for view only. Check again in the "share" settings for the document to see if you can enable access to others such that we may make a copy of it, I'd like to see if I can get your mates working properly
