How to create a section view of a part?
ihor_gernagaihor_gernaga Member Posts: 24 PRO
I am transitioning from Solidworks where there is an option in the tool bar for sectioning. Currently, there is no such tool in my tool bar and it's not imbedded in the available tools.
Thank you.
    If you are in drawings, the button is located here:
  • ihor_gernagaihor_gernaga Member Posts: 24 PRO
    Thank you.
  • imanoleimanole Member Posts: 2 EDU
    I would like to have a section-view only for some parts, not entire assemble. It is possible?
  • Ste_WilsonSte_Wilson Member Posts: 458 EDU
    edited May 2021
    I think it's possible to specify the path of the section line in the drawing. Would that do it?
  • PattabiPattabi Member Posts: 51 ✭✭
    Select the Include option in the top and then select the particular part you want to section. Here is an example.
