Improvements to Onshape - April 12th, 2017
cody_armstrong
Moderator, Onshape Employees, Developers, csevp Posts: 221
It's update time again! We are ready with another round of highly requested features. And the list is long, so let's dive right in.
PROJECTED CURVE
Creates a curve at the intersection of two sketches.
BRIDGING CURVE
Creates a curve between two selections. You can select a vertex/point and/or an edge for each selection.
MERGE SURFACE
When create a surface using the Extrude, Revolve, Sweep or Loft command, you will have a new option to "Add." This will allow you to merge the surface you are creating with a previous surface if they share an edge.
CONICS
You'll find a new Conic command in the sketch toolbar.
COLLABORATING WITH VIEW-ONLY USERS
Users who have been shared into a Document with View-Only permissions can now use Follow Mode and see the Document edited live.
DELETE FACE
There is a new option to "Leave open" that will delete the face/faces selected and leave you with an open surface.
BREAK VIEW
You can now Break drawing views. This is especially useful for long parts that otherwise would be difficult to create drawings of.
IMPORTING CURVES
Onshape now supports importing curves. If you are importing CAD data with curves, you should now be able to see the curves in Onshape.
CURVE IMPROVEMENTS
Curves are now treated more consistently throughout Onshape. This includes the ability to view them as a separate item in the Parts List. Making them much easier to hide/show/rename/delete. This includes helices, imported curves, as well as curves created using the new Projected and Bridging curve command.
FLIP DIMENSION TEXT
Vertical dimensions in drawings have a new elbow point in the leader. Left-clicking this will flip the dimension text to the other side of the arrow.
USER TYPE WHEN CREATING NEW PROPERTIES
When creating new properties, you will see a new option for type called "User." This allows you to search by name when entering in a property value. One example where this would be useful would be an "Approver" property where you want the value linked to a user name and not just a "dumb" string of text.
OFFSET SURFACE
In a previous update, we added the ability to create new offset surfaces that referenced existing faces. Originally, this was added as an option in the "Move Face" command. To make this easier to find, we have decided to remove it from the Move Face command and make it a separate command. You will now find a new "Offset surface" command in the toolbar that will allow you to create new offset surfaces.
Please take a moment to try out these new features and improvements and let us know what you think!
PROJECTED CURVE
BRIDGING CURVE
MERGE SURFACE
CONICS
DELETE FACE
BREAK VIEW
IMPORTING CURVES
CURVE IMPROVEMENTS
FLIP DIMENSION TEXT
OFFSET SURFACE
4
Brian
Especially happy with the possibility to merge surfaces, great update this one.
Thank you guys, keep up the fantastic work.
Thanks OS team.
I always look forward to update day! These 2 simple features were the current #1 and #2 on my request list.
Linked[in]
