Touch support for Onshape? SW 2014 is beating you guys here...
nhfoley
Member Posts: 1 ✭✭
What is the timeline for putting touch based view manipulation controls into Onshape? I have a Surface and an XPS 15, both with touchscreens, and virtually every other CAD program I use can Pan, Zoom, and Rotate by touch input.
With a pen enabled, the ideal input is as below:
Single finger touch & drag: Rotate around first touched point
Two finger touch & drag: Pan
Pinch: Zoom
Right now, it isn't very usable without a mouse, which seems antiquated.
Pinch: Zoom
3
