How to continue pattern?
matthew_lozymatthew_lozy Member Posts: 2
Hi all, I want to create a pattern of lines that are all parallel spaced 1mm apart, however I want the next line in the sequence to be 1mm shorter than the previous line. Is this possible?
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,001 PRO
    edited April 2017
    You want every line progressivly shorter?
    you can create a construction line and add a point that is coincident to the first patterned line, then trim the excess on the remaining lines
