Can i translate/copy a circle(or any other entity) along a spline or raduis?
In the sketch mode: I want to translate or copy a circle along a spline or a radius. can i translate only linear or circular?
thanks for your help!
john_mcclary Member, Developers Posts: 3,948 PRO
Not in a sketch that I know of
but pretty easy outside of a sketch:
https://youtu.be/YupquIPtjVM
Of coruse you will need to calculate the length of your sketch... sorry5
Select all the lines you want, then copy and paste,
then make one of the vertices coincident to the spline
https://youtu.be/CF6ziN0_T3A
