How do I line up these cladding boards in an assembly ?
nick_davies
Member Posts: 11 ✭✭
Hi,
I have various cabins comprised of standard parts and am struggling to line up the cladding with the back wall in this example. https://cad.onshape.com/documents/6d73f4564f0f7e25aef93b39/w/4f62e294c528125ad9c1e74d/e/ac40e598272633285e776946
What you see is the back wall of a small cabin and two boards put more or less in place by hand. What I need to happen is for the boards to overlap the back wall by exactly 15mm and then to continue down the side and be mirrored on the other side. I believe I can do this in a part studio but would have to derive the board to do so. However, I would prefer to do this in the assembly as all our cabins are made up from a library of parts and I want to retain the link to the original board so that I might easily update the cabin in the future.
Any suggestions would be most welcome.
Nick
Nick
It also was not allowing me to slide the shingle to the top of the arc, it would stop about 3 shingles short of the top.
@owen_sparks is right, pattern along curve is made for this.
Sometimes words get in our way. A "part" studio is actually a "stationary assembly" where you can make parts in context. A assembly is a interface between part studios that move in relation to each other.
https://cad.onshape.com/help/#curvepattern.htm?Highlight=replicate
LearnOnshape facebook group
The origin of my problem was trying to place the parts correctly within an assembly in order to preserve the link to the version of the part which is held in a separate document, thus enabling me to seamlessly update the assembly when a new version of the part is produced. Arranging them in a part studio breaks that link.
Early days for me and I accept that I'm probably not seeing something. I'll probably end up shaking all the parts out on the floor and starting again with a different organisational structure : )
With Onshape we are all relatively new at this. I have spent many times shaking all the parts out on the floor, several iterations on a single document in some cases. In the end it is worth it to do that some times.
