How to make this gearing rotate properly
I created a gearing with intermediate rolling elements, but can't make all the rollers move properly because pin slot mates (that should make rollers move in the slots of separator) starting randomly flip direction by 90 deg, when i'm starting to rotate output shaft
https://cad.onshape.com/documents/5b127d8c24b2f4fe30160ab3/w/a4007bd59e449c044bc650ae/e/d39c27f81560c534939f963f
this video shows how it really works, though it is in russian
https://www.youtube.com/watch?v=fAamyym1XCk
1
It's not perfect, but you may have to look into the profile on the outer ring.
The top roller bearing stays seated while others show gaps.
If you follow my mouse cursor you can see what I mean, it lines up perfect on one side but not the opposite side
https://www.youtube.com/watch?v=FeVg7sP3wVk&feature=youtu.be
Also don't forget the intermediate ball bearing between the cam and the outer roller bearings
But this is over my head
I just buy these gearboxes, not make them
About tangent mates - I just have to use them to make sure all the rollers are in contact with three part at a time
