Trying to make intersecting pipes filleted of fixed thickenss.
jrs_spedley
Member Posts: 71 ✭✭
I want a small diameter pipe to penetrate a large diameter pipe to form a T shape. I want the joint filleted (internally) to improve fluid flow in the pipe but I also want a constant material thickness for casting.
I've tried using the fillet tool on solid parts but because of the curved path of the joint the thickness varies.
My next try was to model the internal surface and then thicken the part but I can't join the two pipe surfaces together so I can fillet the joint.
Is there a standard way of doing this sort of thing? Is there any way of doing this? My next try will be make the solid parts and then delete the external faces then fillet and thicken but it feels like a botch and I don't like botches.
NeilCooke
Moderator, Onshape Employees Posts: 5,926
Solid pipes, fillet external edge, shell.Senior Director, Technical Services, EMEA5 -
jrs_spedley
Member Posts: 71 ✭✭
Excellent idea, not only does it produce very good results but the sketches were much simpler and the flexibilty for design changes greatly increased.
Thanks!
(P.S. it is a heat exchanger)
Thanks!
