How do I use construction lines across sketches?
gyrex
Member Posts: 32 ✭✭
Hi everyone,
I'm completely new to CAD and require some help please. I'm trying to create a construction line which exists on a different sketch and use this line on another sketch (which happens to be on a different plane as well). Is this possible? I need to use this line in order to align entities on another sketch. Is this possible? Or is there a better way to achieve this?
Thanks in advance for any help!
My drawing is here: https://cad.onshape.com/documents/7acaac9aa46245186225afb6/w/239620736401d6f7997c98fb/e/be0be3939a5deeed67f257fd
owen_sparks
Member, Developers Posts: 2,660 PRO
Hi.
Yes, indeed you can.
There is a "use" command to use aka project an entity onto something else.
@lougallo might be worth noting in passing that even though I knew the feature I was looking for when I typed "use" into the OS help search I got zero hits.
Cheers,
HWM-Water Ltd5
Cheers,
https://cad.onshape.com/help/#sketch-tools-use.htm%3FTocPath%3DPart%2520Studios%7CSketch%2520Tools%7C_____17
Cheers,
Cheers, Owen S.
