Cadence Allegro DXF Import
randy_rosales
Member Posts: 3 ✭
Hi,
I am running into a problem when importing a DXF which was exported from Cadence Allegro 17.2. The problem is that objects composed of arcs (LWPOLYLINE objects I believe) such as curved copper pours and trace etches are importing in as coarse line segments which approximate the arc. Fully circular objects, like vias, drills, circular BGA pads, import correctly, as do line segment based shapes.
I have imported the same DXF into eDrawings 2017 and the curved copper pours resolve correctly. So I do not believe I am doing anything wrong with the DXF export options from Allegro.
Is there something I can do from the Allegro DXF export options that might help. Is this a known limitation in OnShape?
See below example pictures for each case.
Thank you,
Randy
Original ECAD curved shape example
Imported DXF in OnShape
Imported DXF in eDrawings
Thank you,
Randy
If you could do an ltscale command like in AutoCAD it would come good.
I know this wont directly address the issue you raised as the IDF files dont include things like the copper pours but if your ultimate goal is to get your board into Onshape it might do some of the heavy lifting.
-Marc
