STL export - tapped hole threads not showing up in 3d print slicer
mark_casey
Member Posts: 17 ✭✭
Title says it all. I've made a simple tap handle with a threaded 3/8-16 hole to directly screw onto a tap.
The intent is to 3d print the part with the threads integral to the part. It exports fine but the threads are not showing up in the slicer and thus will not print.
If fact, the threads do not show up in the Onshape part display although they are defined as being there using the Hole command.
I'm sure I'm doing something wrong, but just can't figure it out.
My tap handle is available publicly at
https://cad.onshape.com/documents/9c35aff9403733481b7cec82/w/9f21851b66cf7e794f5394f4/e/d67efd1deb907b02b5d0b924
if anyone cares to look.
thanks in advance for any advice.
Mark
Mark
lougallo
Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,015
@mark_casey Our hole feature does not add threads. Just the tap drill diameter. If you want to print threads you will need to add the threads yourself or look for a featurescript that can cut them for you.Lou Gallo / PD/UX - Support - Community / Onshape, Inc.3 -
Jake_Rosenfeld
Hi Mark,The issue you find with your file size is actually why we don’t add threads. From a tessellation point of view, threads are very expensive to create as they require a very large number of triangles to represent. The average user does not need these threads, as the metadata for the thread carries over to our drawings, and the user can annotate the drawing to actually drill this hole at the manufacturing stage, and at no point has to slow the document down by adding these very small, but expensive, cosmetic features.That being said it is a valid use case to need these threads for 3d printing, and if you would like to see this feature in the product you can raise an improvement request to the right -->Jake Rosenfeld - Modeling Team3 -
owen_sparks
Member, Developers Posts: 2,660 PRO
The rise in file size is normal, and is a reason most folks chose not to model the threads themselves unless really needed. There will probably be more triangles in that little thread than the rest of the model put together.
I do a bunch of 3D printing using OS files. How big a thread do you need? If they're not large then I'd either print the pilot hole and tap it (if using a suitable material) of have captive nuts included part way through the print. I got fed up doing this manually so wrote a Nut Pocket featurescript to do it for me. Or melt in threaded inserts.
Cheers,
HWM-Water Ltd5
Apart from this (minor) frustration, I find Onshape extremely useful and powerful. I'm new to CAD and if I think about what I'm trying to accomplish in advance, it really is fairly intuitive.
thanks for taking my question.
Mark
Cheers,
It seems that there must be a more efficient way (not that I know how) to create threads.
As a test, I created a 2 inch cube and then a 2 inch cube with a 3/8-16 threaded hole 1 inch in length. The resultant .stl files were 684 bytes and 4.13MB respectively.
I did the same thing in TinkerCad and the resultant .stl files were 684 bytes and 182 kB respectively.
Seems there is an opportunity to make a more efficient threaded item.
I'll make the request.
thanks again.
best,
Mark
Great work, the thread creator works perfectly
Please reconsider adding threads in exported parts @onshapeteam, filesize is not a concern for many simple use cases, and having to manually model internal threads like ACME, NPT, etc. is a huge pain.
I shouldn't need a tap/die set to make something as simple as a 3d-printed 3/4" NPT nut.
