STL export - tapped hole threads not showing up in 3d print slicer
mark_caseymark_casey Member Posts: 17 ✭✭
Title says it all.  I've made a simple tap handle with a threaded 3/8-16 hole to directly screw onto a tap.
The intent is to 3d print the part with the threads integral to the part.  It exports fine but the threads are not showing up in the slicer and thus will not print.
If fact, the threads do not show up in the Onshape part display although they are defined as being there using the Hole command.
I'm sure I'm doing something wrong, but just can't figure it out.
My tap handle is available publicly at
https://cad.onshape.com/documents/9c35aff9403733481b7cec82/w/9f21851b66cf7e794f5394f4/e/d67efd1deb907b02b5d0b924
if anyone cares to look.
thanks in advance for any advice.
Mark
  • mark_caseymark_casey Member Posts: 17 ✭✭
    Any plans to add this feature?  It seems like a fairly basic need.  The process to add threads is vey kludgy and when I follow steps in the video tutorial that I found after posting this question, my system does not react the same way.  I have been unsuccessful in using the helix and extrude surface tools to create a threaded hole.  I found a beta featurescript and am not sure how it works, which it does, but adding one 1 inch 3/18-16 tapped hole to a part increased the size of the stl file by 5.4MB (or more than quadrupling the file size).
    Apart from this (minor) frustration, I find Onshape extremely useful and powerful.  I'm new to CAD and if I think about what I'm trying to accomplish in advance, it really is fairly intuitive.
    thanks for taking my question.
    Mark
    Doh, Jake got there before me, sorry.
    Thank you both.
    It seems that there must be a more efficient way (not that I know how) to create threads.
    As a test, I created a 2 inch cube and then a 2 inch cube with a 3/8-16 threaded hole 1 inch in length.  The resultant .stl files were 684 bytes and 4.13MB respectively.
    I did the same thing in TinkerCad and the resultant .stl files were 684 bytes and 182 kB respectively.
    Seems there is an opportunity to make a more efficient threaded item.
    I'll make the request.
    thanks again.
  • ilya_baranilya_baran Onshape Employees, Developers, HDM Posts: 1,230
    The file size is purely a function of how finely Onshape tessellates the thread.  You may also consider using the thread creator custom feature: https://forum.onshape.com/discussion/4867/new-featurescript-thread-creator
    Thanks!  I'll try that.
    Turns out this is the feature script i was using.  it makes beautiful threaded parts but results in extremely large .stl files.
    best,
    Mark
    Is the time of terabyte hard drives and gigabyte USB sticks there any downside to large files?
    Storage is pretty much a non-issue, but the 3d slicers choke on them a bit.
  • tom_leenheertom_leenheer Member Posts: 6
    Mark,
    Great work, the thread creator works perfectly
