Multi-tab workflow "update in progress" notification
billyzelsnack
Member Posts: 96 PRO
I typically do a lot of work across multiple tabs and when I make a change to one tab and flip back to another tab it often takes multiple tens of seconds for a change to propagate to my current tab. I think it would be cool if there was immediate visible notification that the system is busy working and that you should soon expect an update. I'm not suggesting changing the cursor to a spinner, but maybe animating the user icon for the tab that changed that will soon impact your current tab.
The delay itself is not really the underlying issue for me. It's just the lack of a system busy indicator in the current tab. I really like the multi-tab workflow to make a change where something is more accessible to edit but quickly switch to another tab to await the result. I find myself toggling back and forth waiting for the change to show up where I made the edit. When you stay in the tab where you made the edit you get the busy spinner so you know that the system is working for you. Switch to another tab and that busy feedback goes away. I toggle back and forth because it's not uncommon for an edit to not go as planned and I end up twiddling my thumbs waiting on the system that's already finished its work.
Put maybe more succinctly.. I think the same reasoning for a system busy indicator in one tab applies to any other tab where the system will soon make a change to.
