Section view tol stack
John_Carver
Member Posts: 6 ✭✭
Can I create section views then annotate for use in tol stacks? Then maybe save for later reference
https://forum.onshape.com/discussion/134/how-can-we-make-section-views-awesome-in-onshape/p1
please add me to this request.
Maybe OS could be the first cad to bury separate 2D drawings and maybe have a button to export live dwg for those who like. Most likely DraftSight is already better for 2D than OS will ever need to create?
+1 for saved views over drawings
If we ever get together at some OS rally, the 1st round is on me,
If I remember correctly you are a Alibre/Geomagic user. You know that with just a few key strokes GM will give you 2D drawings with all the views you need. You also know that you can then dimension the drawing the way you want, print it and take it to the shop.
This is what I need with OS
Dave
Ariel, WA
@David_Sohlstrom12345 According to your description, you don't need traditional 2D Drawings made in some historic way. You just need certain 2D prints from your 3D model with visible dimensions to be able to produce them, correct?
For some reason those 'few keystrokes' in GD to create 2D drawings for production tend to use more time than I have spent on actual modeling. In 3D, everything is just so easy - it's not like I don't need 2D drawings, I just don't need the clomsy 2D editor to create them.
I'm actually using more and more just screenshots from 3D and sketch environment for our own production.
Of course formal documents can't be done this way, but again export live dwg (updating when model changes) should serve better those people than some left-hand-made 2D mode.
good, sounds like we'll become good friend.
Dave
Ariel, WA
Mike
For one thing, 2D drawings are the only truly future-proof output format; that alone is sufficient to make the capability essential.
At this point it's great wisdom to keep eyes wide open for new approaches and not just rebuild solid works.
Normal 'double work' cads with separate 2D can be found in every price class so it's not about preventing people from doing their work if OnS would choose another route. It's way better to wait another year to get this into active production use than repeat same old stuff in hurry to be stuck with for next 10 years.
Can someone 'married to drawings' comment could it be possible to do your 2D work like this:
Work in part studio or assy, turn model in wanted position, select visible dimensions, add annotations, hole callouts, detailed/section view and other stuff, then click save view.
It would create a block which could be placed on print template or just quickly printed straight from workspace.
My main idea would be to work in the same environment where you design and push views to prints rather than beginning from blank screen after finished modeling and start importing stuff, adding dimensions again, selecting views by turning model 90 degrees rather than using mouse or standard views 'cube'...
Of course this would need much more thinking than copying the best of current cads drawings, but I think OnS people have already showed us they can do something else than others. This is just my opinion, maybe I'm wrong?
The problem I have with your proposal is that the needs of the human interpreting a drawing are usually very different from the needs of the person building a model.
The implications are numerous, but one is that the same dimensions (eg between the same points) are often simply not suitable for these two parties. And even if they are, they will generally be in the wrong location, or visible from the wrong view.
It is not always feasible to rectify this at the end of the modelling process, by redistributing and reassigning dimensions, because the model needs to continue to be able to be revised. This is a big topic I cannot do justice to here, but it's one reason why many users do not find automatic creation of drawing dimensions from the model to be useful or even usable.
Incidentally, I don't understand your implication that Solidworks is detrimentally slanted towards 2D. For many years, their 2D output was clearly an afterthought, and a badly implemented one.
I can see merit in aspects of your proposition to generate drawings from within model space, for instance it would be nice if the ways of assigning views in a model were aligned with the ways of doing it in a drawing. This can be done in Solidworks by assigning views, BTW, but it is clunky purely because of the two-environment problem you identify.
Your proposal might fly if we were enabled to toggle the dimensioning schema of a model between one for modelling (input oriented), and one intended for drawing (output oriented). It would certainly be advantageous to put a major effort into streamlining the creation of drawings. And I agree that dimensioned 3D views can be useful in some situations.
This is not aimed at any particular poster, but at the prevalent notion that 2D drawings no longer have relevance (as well as narrower notions, such as "all tolerances should be symmetric"):
Those who are building intake grids and machinery housings for a hydro dam, or terminal stations for an aerial tram, or interior fitouts for a production sailboat, have rather different needs from those running a CNC machine or a 3D printer.
2D drawings provide a generic language with a very wide degree of applicability, and that makes them sub-optimal to some players in narrower fields. Everyone is free to develop their specialised language for a particular field, but they need to recognise that there may be show-stopping limitations which prevent their language from having more general application. The global optimum can never be the sum of local optima, and engineering will continue to need a single "lingua franca".
