Can I Import an EPS file into onshore to work on it
mario_darceuilmario_darceuil Member Posts: 113 ✭✭
I have an EPS image of a deer. I just need the outline in 2d so I can put holes for bolts and screws. Is it possible to import this into onshape? If not can I enter the xy ordinates of the image to get the profile in 2d into onshape?
  • mario_darceuilmario_darceuil Member Posts: 113 ✭✭
    How to use the x,y ordinate feature of Onshape?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,845
    You could try this nifty little tool then import the resulting dxf into your sketch
    https://cloudconvert.com/eps-to-dxf
    Thank you guys for the help, I will try these methods to get my image into onshape to work on it. I'll let you know how it goes.
