Dimension on hidden line.
Any reason I can't put a dimension on a hidden line in a drawing???
PeteYodis Moderator, Onshape Employees Posts: 559
We are working on the ability to dimension to hidden lines. We know this is important, even if frowned upon by some.5
You can create a section view and dimension it
Unfortunately it is currently not possible to create:
- A partial section view
- An inclined section view (other than horizontal or vertical)
- An aligned section view
I'd also like to able to add centre lines to hidden lines. Not sure if this outside the standards but I find it extremely useful to add centre lines to hidden lines showing holes through plates and lugs on my drawings.
Even in a simple example like the one in the image we are currently having many difficulties in creating a drawing with all the complete information.
Thanks
