Going crazy with onshape moving my objects.
scott_caskey
Member Posts: 53 PRO
When I add a radius and change the dimension of the radius onshape decides I need to move my line over some arbitrary amount instead of shortening both lines the required amount for the radius. Now another issue when I am adding a line in a sketch, wherever I stop my line and then enter a dimension, it doesn't make it that length from the start point, it makes it that length from the end point! So it screws up my sketch. I can't seem to escape whatever mode this thing is in. Man this stuff is frustrating.
1
Autoscale only takes place when adding the first dimension of sketch.
I too think Onshape has the best sketcher in the industry, after two years of use (and many updates) I don't have any major complaints.
I have this after i strictly constrain EVERYTHING, and work on something for 5 hours to find out that it has decided to shifted everything.. slightly and randomly for no reason so i have to delete everything and restart.
If you are struggling with sketches, you need to learn about constraints (this is very important - you can't shortcut this). Make sure you fully understand what each one is, and what they do, and how to use them. Take them one at a time, go to help, or the learning center - and research everything that all of them can do. Once you gain this basic knowledge, I bet you won't have anymore problems with sketches.
Good luck
@jayce_fry
If this is based on what you posted on the other thread, the issue is that your sketch is way too complex…
Onshape will eventually stop solving sketches that have too many constraints.
