Can I Import an EPS file into onshore to work on it
I have an EPS image of a deer. I just need the outline in 2d so I can put holes for bolts and screws. Is it possible to import this into onshape? If not can I enter the xy ordinates of the image to get the profile in 2d into onshape?
3dcad Member, OS Professional, Mentor Posts: 2,476 PRO
You might wan't to convert eps image to png or jpg and then import to Onshape (I'm not sure if eps is supported).
Then open new sketch - insert dxf/image - your imported image should appear on list - insert - add one dimension to set the scale.
Then you can draw on top of your image and trace the edges - no automation here.
//rami5
https://cloudconvert.com/eps-to-dxf
