How to copy part studio and keep the context
jon_loschke
Member Posts: 32 ✭✭
I have a part that is designed in context. I need to make a variation that also depends on the context. If I duplicate the tab or copy to clipboard and insert back it doesn't keep the context. Is there a way to copy the context as well?
NeilCooke
Moderator, Onshape Employees Posts: 5,979
Short answer, no. But if it is only a small variation, create a copy of the part (using transform/copy in place) in the same part Studio and add further features or use move face to make the mods.Senior Director, Technical Services, EMEA6 -
Jake_Rosenfeld
You could also branch off of the current workspace and make the edits you want in the new branch.
https://www.onshape.com/cad-blog/tech-tip-branching-designs
Jake Rosenfeld - Modeling Team5
Hi guys, anything new about the topic?
Tried the same, failed.
Is there really no way to keep the context when copying an in-context-partstudio after all these years?
Or a way to link the partstudio to the context after copying?
PS:
The Link regarding branching doesn´t seem to work anymore.
