Drawing
carlo_bellinicarlo_bellini Member Posts: 2 PRO
Hi,
can you suggest me if there is a featurescript function that make a drawing of a part?
I want to create a part and then call a featurescript to make the drawings.
Is it possible?
Thanks
Carlo
    Hi @carlo_bellini FeatureScript is only for creating 3D features.
  • carlo_bellinicarlo_bellini Member Posts: 2 PRO
    OK.
    Now it's clear.
    Thank you NeilCooke
  • tim_snell803tim_snell803 Member Posts: 5 PRO
    Is this still the case? If so, is there any way to do this? E.g automatically create a drawing of x parts in y orientation?
  • john_mcclaryjohn_mcclary Member, Developers Posts: 3,959 PRO
    edited October 2019
    Yes, and I would say it is always true that feature scripts only geometry in a partstudio.
    You may want to look into API to make drawings. Even that may be tough, I'm not sure how much of drawings is exposed.
    You're better off creating your drawing, then duplicate and replace references, or something along thoes lines
