How to relate animations?
Kiyoun
Member Posts: 2 ✭✭
I have two questions.
First, when I move the gray bottom plate, I don't want move the sky blue plate.
When I rotate the gray bottom plate, The sky blue plate is also rotated as shown a below figure.
And, there are three foldable side plates. I want to make a animation so that these plates open sequentially. Is there any method?
Thank you.
john_mcclary
Member, Developers Posts: 3,998 PRO
You can use a few, gear relations, or rack & pinion relations it your tricky.
If you link your document I could take a stab at it
5
