How to copy part studio and keep the context
I have a part that is designed in context. I need to make a variation that also depends on the context. If I duplicate the tab or copy to clipboard and insert back it doesn't keep the context. Is there a way to copy the context as well?
NeilCooke Moderator, Onshape Employees Posts: 5,859
Short answer, no. But if it is only a small variation, create a copy of the part (using transform/copy in place) in the same part Studio and add further features or use move face to make the mods.Senior Director, Technical Services, EMEA5 -
Jake_Rosenfeld Moderator, Onshape Employees, Developers Posts: 1,646
You could also branch off of the current workspace and make the edits you want in the new branch.
https://www.onshape.com/cad-blog/tech-tip-branching-designs
Jake Rosenfeld - Modeling Team5
