Move Face Not Possible Until After Finishing Sheet Metal Part
eric_lau
Member Posts: 17 ✭✭
Hi Guys,
I am having a hard time figuring out why the move face feature will not work on my sheet metal part. If I "finish" the sheet metal part the move face feature and/or face extrude work as expected however since the sheet metal part is already finished the extended tab doesn't show up on the flat pattern. Any tips?
This looks like a bug, we'd be happy to check it out! Please report a feedback ticket (In your document press ? > Feedback) and check the "Share this document with Onshape support" button.
Thanks!
In mean time, you can work around this issue by setting bend relief at the closest bend end to tear and then cutting it out yourself. This would allow that face to move.
