Convert a series of connected lines to a smooth spline
bert_drakebert_drake Member Posts: 3
When drawing a sketch, is there any way to convert a series of lines to a smooth spline, or polyline, like in autocad?
  • mthiesmeyermthiesmeyer Onshape Employees Posts: 115 image
    Hi Bert,
    You can use the `Composite Curve` tool to convert multiple curves into one curve when you are using it with other features. You can see the help page here.
    Best,
    Mike
  • billy2billy2 Member, OS Professional, Mentor, Developers, User Group Leader Posts: 2,119 PRO
    edited June 2017
    bert-
    Here's 3 lines in a sketch:
    As Michael says, composite curve:
    I wrote this fit spline with feature script that builds a smooth curve through input geometry & fit parameter:
    Theres also a fit spline in the curves menu drop down, which is driven by vertices & magnitudes:
    So what's the difference in my fit spline & OS's fit spline?
    Different approaches:
    I follow curvature and they follow vertices.
    I follow the input curves based on a tolerance:
    Anyway, yes OS can compose curves in many different ways.
  • david_velozdavid_veloz Member Posts: 4 ✭✭
    If it’s a closed spline contour try exporting the sketch as a DWG (haven’t tried DXF, but may also work) making sure to check off the “Export splined as polylines” option. Create a new part and import the file you just exported.  :/
