Supported browsers and lots of other performance information can be found on this page:
https://cad.onshape.com/help/Content/webgl.htm
Additionally, you can use:
https://cad.onshape.com/check
Once the "Performance Check" section of the second page finishes running, you can see a profile of how your graphics card stacks up. If you run the performance check on multiple browsers, you can see which performs the best for your setup. (You should close all the other programs on your computer, just open the browser you want to check, and close all tabs besides the performance checker)
Onshape is supported on the most recent stable release of the following browsers:
• Google Chrome
• Mozilla Firefox
• Safari
• Opera
Onshape is NOT supported on:
• Internet Explorer
• Microsoft Edge
• Mobile browsers
Unsupported browsers lack full support for WebGL and JavaScript, the two critical components
for rendering Onshape’s graphics and user interface. This means that various commands and
graphics artifacts either won’t display at all, or won’t work on those browsers.
Browser Performance
Chrome is typically the fastest browser on new machines with up-to-date drivers and a dedicated
graphics card. It is good if you are often switching between many tabs consisting of small-to-midsized
models.
Firefox tends to allow more memory usage when compared to Chrome and may be preferred
when dealing with large models across fewer tabs.
Source:
Onshape Hardware Recommendations
When Using Onshape for Professional Work (Jan 2017)
At the moment I'm pretty satisfied with chrome for onshape, I try to close it at least once a day and use firefox for other browsing and opera for radio etc. always on stuff.. I have had better overall experience using different browsers than many instances of single browser.
In my case I currently have around 15 model tabs (but still growing) plus as much imported file tabs in the same workspace. While some tabs may contain only 100 features and 100 parts, the biggest model has close to 300 parts. We are two person working simultaneously in that workspace and I can tell you patience is a required virtue.
Can you work in different workspaces and merge work later? I did try co-operation in shared workspace few times in past but it was way too slow to get anything done. This can also happen if you have same workspace opened in multiple windows.
On windows, chrome seems to be the smoothest, but firefox is the most stable.
