Cannot make Pierce constraint work on Onshape mobile
I'm well versed in the operation of Onshape desktop, but I'm now trying to learn Onshape mobile on an iPhone.
As a tutorial I'm trying to build the classic threaded nut. But I've come across a problem trying to make pierce work in this example. It works fine first time on the desktop version, but on the mobile version, however carefully I pick the required points, the pirece fails and Onshape just moans with a red message at the top of the screen saying something in the sketch has to be selected.
I don't see what I'm missing here. I have the sketch open and I select the Pierce constraint icon, then I select one corner of the triangle and the end of the helix, but it does not work, even after many attempts.
https://cad.onshape.com/documents/ddc3895a96a83ba1a26425a8/w/25dce64cde8d0c47d307f18a/e/1e5f24ef951ab7f8a660a613
Is something wrong with the mobile implementation, or am I doing something wrong?
Cheers
Cheers
If you select the corner of the triangle and the end of the helix, and then select the pierce constraint, it should work.
