Folders
Folders are a neat idea but I need a "Tips & Tricks" video. Folder behaviors are confusing me.
My need is to reduce tab count by grouping similar parts into folders to make it easier to find parts and assemblies.
bill_daniels Member Posts: 278 ✭✭✭
After two days of struggling, got my large project organized. I now think I have at least a beginners understanding of how folders work.
The first take home is to never let a project get as disorganized as I did. The second is that folders and the whole project organization process could be more user friendly1
Today, any elements in a document may be put into a folder.
Folders may be nested
To find any part or assembly by a number of different criteria, please use the 'Advanced Search' capability.
I'm sure this is simple stuff but I need to know all about folders to use them effectively. One document I've created has over 3,000 tabs so finding the ones to drag and drop into a specific folder will be a pain if I have to do it one at a time.
@bill_daniels - the advanced search is accessed from the drop-down at the end of the regular search dialog.
I can't search for a folder within the Tabs Manager as folders don't appear there. I am beginning to think there is no efficient way to move Part Tabs into a folder nor to find that folder again. Since folders appear in the tabs bar at the bottom of the workspace, it's reasonable to expect they would behave just like tabs meaning that folders would appear in the Tabs Manager and be searchable just like any other tab. Since they are called "folders" with an icon that looks like any other folder, it's reasonable to expect they would support a group select, drag and drop behavior just like any other folder.
I think folders could be very useful and they keep the idea of a document as a 'project container'. Scattering parts across multiple documents defeats that idea and the concept of a 'workspace'.
If you are a Pro user, please go ahead and submit the ticket directly from within Onshape. If you are a free user, please submit this through the enhancement request section of the forums.
@bill_daniels - I'm not sure why you are not seeing the folders in the Tabs Manager. I see them there, and that's where I do most of the organization. It behaves pretty much like you are wanting - selecting a bunch of tabs and dragging them into the folder, or right-clicking on them to add them that way.
Here is a link to the "What's New..." video where they were introduced that shows how they should behave:
https://www.youtube.com/watch?v=nHptksWl2gs
There is also a longer webinar that goes into organizing your documents (including folders) here:
http://https//www.youtube.com/watch?v=0a7JDvQPIFE
What would really be useful is to be able to select a bunch of tabs in the manager then use a "Move To" command to place them in a folder.
Then I accidentally click twice on a tab in the manager and OS zooms off to display that PDF - and the PDF tab vanishes and I can't find it again.
