pipe taps
I do mold design and I need to be able to model in pipe taps. Does onshape have this ability?
Then do a sweep cut for the thread profile.
You can then add this to your library and use it anywhere by deriving it and doing a boolean subtract on your recieving part.
There is also a thread generator feature script made by @dave_cowden. https://cad.onshape.com/documents/6b640a407d78066bd5e41c7a/w/4693805578a72f40ebfb4ea3/e/f8aea9e5c33e02eab0854a4f
It only does straight threads, but The meat is there you may be able to make it do pipe thread as well.
