Multiple parts from the same sketch in part studio
fitz_terra
Member Posts: 4 ✭✭
Hi all,
I have a sketch of the face for an aluminium profile which I now want to extrude to four (or multiple) parts of different lengths. The idea being that each of these lengths of alu extrusions will then be used multiple times in an assembly to build a frame.
Since the profile face is the same, my expected flow would be to draw one sketch for the face, then extrude this multiple times to the various lengths. The problem is that all extrusions for new parts are in the same place in part studio. This should probably not be an issue once bringing them all into the assembly (I have not tried this yet), but it is very confusing in part studio with all parts on top of each other, centred around the origin of the single sketch.
Is there a way to move an extruded independently of the position of it's underlying sketch, or is there a better flow? Should I just copy the sketch for each length of extrusion I need in the same part studio? Any other suggestions?
Thanks
Thanks
owen_sparks
Member, Developers Posts: 2,660 PRO
Yes, either:-
(a) Do what you've done and then use the "transform" function to move them where you want.
(b) Make one, use the "linear pattern" tool to copy your "seed" into a bunch of them in a row, then "extrude" each individually to whatever lengths you need.
OwS
HWM-Water Ltd5 -
Jake_Rosenfeld
Hi All,
I would go with Owen's suggestion of (a). Because external reference constraints need to be broken for a sketch-feature pattern, a patterned sketch may not be identical to it's seed (this is a known behavior to us with fixes on our radar). The best option would be to use the one sketch to create your solid parts, then use the "transform" tool to move them out from under each other.
https://cad.onshape.com/help/Content/transform.htm
Jake Rosenfeld - Modeling Team5 -
NeilCooke
Moderator, Onshape Employees Posts: 5,927
If they are to be used in an assembly then you never need to see them in the Part Studio. So if they are on top of each other does it really matter?
The other option is to use the FeatureScript Beams feature and design your own profiles if it is something you do regularly.Senior Director, Technical Services, EMEA5
OwS
@NeilCooke 's comment about how not having to worry about the view in Part Studio when the parts are used in an assembly is valid, and exactly what I found when starting to play with the assembly.
The only time you may want to view them all separate in Part Studio is if you need to make adjustments where seeing the full part would be helpful, but even then, you could just hide the other parts.
As an exercise to learn more, I will test out the transform tool, but I'm suspecting it may change my origin for placement in the assembly, which may not be ideal if this is the case. I'll have to go test this.
Anyway, thanks for the feedback and I will also check out FeatureScript Beams.
